the front driver side brake keeps sticking it will lock completely and you cant move the car at all
Oct 5, 2010 at 10:00 AM
✓ASE Certified Mechanic
Check the brake caliper piston could be corroded and also the brake hose if its collasped internally acting as a one way check valve
Oct 5, 2010 at 10:03 AM
MMPRINCE4000
Remove caliper and inspect slide pins. If siezed, replace caliper.
Oct 5, 2010 at 10:04 AM
