1998 Toyota Corolla
1998 TOYOTA COROLLA
BLLOYD123
Engine Mechanical problem
1998 Toyota Corolla 4 cyl Automatic 199000 miles
I have an oil leak that leaves the residue at the oil valve gasket. I changed it and torqued it to 89 in-pounds but still have the leak. what is the cause, maybe i did not torque in the right way, I tried to do a criss cross method. I put the RTV seal on what I thought was the timing chain cover joint but wonder if I should put the seal around the whole matting surface of the gasket cover.
Oct 3, 2008 at 7:10 PM
  • 31,937 POSTS
Hi there,
if the gasket is sitting in the grove ok, i would just tighten it down a tad more, don't go crazy, and you should not need any sealant, did you use a genuine gasket?
mark (mhpautos)
Oct 3, 2008 at 8:42 PM
