1997 Toyota Corolla Unknown Problem
95,000 MILES • 4 CYL • FWD • MANUAL
KREMILS
Hi there! My corolla is still not running well until now. it will run only for a few kilometer after starting and suddenly it will stop. i change the fuel filter and fuel pump as well as the air cleaner. i drained the fuel tank already, but the problem is still the same. It is a 2E engine with a carburetor. Can you give me a diagnosis with my problem? how about the distributor cap? Do you think it's an electrical problem? is it possible? thanks..
Jul 24, 2009 at 10:51 PM
MMPRINCE4000
  • 8,548 POSTS
If, when the car stops, and you spray starting fluid down the carb, if it runs a for a second then it is fuel related. If it doesn't run it is an igniton problem, ignition module is most likely.
Jul 25, 2009 at 12:34 AM
