1997 Toyota Corolla Tire Size cahnge
97,500 MILES • 4 CYL • FWD • AUTOMATIC
CUBCADET86
I have 175/65R14 tires on the car at this time & I need change for new. Can I put a 175/60R14 on the same rim? My reason, I would like a little wider tire I think it would make it handle & look a little better.
Jun 4, 2009 at 12:02 AM
MMPRINCE4000
  • 8,548 POSTS
As long as overall height and width do not interfere with suspension, you would be OK.
Going from a 65 to a 60 should not cause any problems, although speedometer may be slightly off.
Jun 4, 2009 at 12:08 AM
COLEFFBS
[quote:fe59899f72="cubcadet86"]Tires and Wheels problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Automatic 97500 miles
I have 175/65R14 tires on the car at this time & I need change for new. Can I put a 175/60R14 on the same rim? My reason, I would like a little wider tire I think it would make it handle & look a little better.[/quote:fe59899f72]
If you want a slightly wider tire, try going with a 185 or 195 -65/14. I have a Corolla S that has the 195-65/15 on it as the stock tire for my model. If you check with tirerack.com, when you list the specs for the tire size, you should also find the recommended rim width too.
Jun 5, 2009 at 7:15 AM
