Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Serpentine Belt
Symptoms
Squeak
1997 Toyota Corolla Sqweecking sound when car is on
1997 TOYOTA COROLLA
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSERRATOS
MEMBER
there's a sqweecking sound when the car is on like belts loose but I adjusted the belt and the sqweeking sound still come on when the car is on
Nov 24, 2009 at 3:22 AM
MMPRINCE4000
Experienced Mechanic
Possible belt tensioner or idler pulley bearing. Also if belt is contaminated with oil or coolant, it WILL squeak.
Nov 24, 2009 at 10:12 PM
JOSERRATOS
MEMBER
ithank you so much. it was oil. the car is leaking oil
Nov 25, 2009 at 1:28 PM
MMPRINCE4000
Use brake clean to remove oil from pulleys.
Nov 26, 2009 at 12:44 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
