1997 Toyota Corolla Sqweecking sound when car is on
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSERRATOS
there's a sqweecking sound when the car is on like belts loose but I adjusted the belt and the sqweeking sound still come on when the car is on
Nov 24, 2009 at 3:22 AM
MMPRINCE4000
  • 8,548 POSTS
Possible belt tensioner or idler pulley bearing. Also if belt is contaminated with oil or coolant, it WILL squeak.
Nov 24, 2009 at 10:12 PM
JOSERRATOS
ithank you so much. it was oil. the car is leaking oil
Nov 25, 2009 at 1:28 PM
MMPRINCE4000
  • 8,548 POSTS
Use brake clean to remove oil from pulleys.
Nov 26, 2009 at 12:44 AM
