1997 Toyota Corolla SHIFTER LIGHTING
RCOSTANZA
  • 1997 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 132,000 MILES
SHIFTER LIGHTING DOES NOT ILLUMINATE IS IT A BULB OR FUSE PROBLEM?
Tuesday, March 17th, 2009 AT 10:59 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuses first, otherwise you will have to remove shift console cover to replace light bulb.
Tuesday, March 17th, 2009 AT 2:09 PM
PMP
  • 177 POSTS
Its the bulb I have the same car 97 corolla its kinda a pain to get the bulb out make sure you have plenty of time.
Thursday, April 2nd, 2009 AT 2:21 PM
MMPRINCE4000
  • 8,548 POSTS
Best thing to do is to use car repair manual link in this thread or get a Haynes manual.
The console can be a pain to remove and has to be done in a certain sequence. Once you have replaced the bulbs, check their operation before you reinstall console.
Friday, April 3rd, 2009 AT 7:01 AM
