1997 Toyota Corolla screeching sounds
PARUL
  • 1997 TOYOTA COROLLA
  • 6 CYL
  • FWD
  • 104,300 MILES
My car makes loud screeching sounds when I first turn on the car, and it lasts about 30 seconds to a minute. What is the problem? Is it the timing belt? I have never had it changed. If it is the timing belt, do I have to change the water pump, too? How much can I expect to pay?
Monday, April 21st, 2008 AT 1:59 PM
  • 31,937 POSTS
Hi there,
Check the Alternator and power steering belts first, Cam belts don't normally squeal like that. If you have not changed the Cam belt it may be a good thing to consider. You do not have to change the water pump, if it is still serviceable. Have the idler pulleys checked and the cam & crank shaft oil seal inspected as well. As for cost, You best ring around and get a quote as I do not live in USA an I have not currently got access to the relevant data base to advise accordingly.
Mark (mhpautos)
Wednesday, April 23rd, 2008 AT 7:10 AM
