1997 Toyota Corolla Running Hot
100,000 MILES • 4 CYL • FWD • AUTOMATIC
CORNELLIOUS
My car is running hot i've replaced the thermostat the water pump is not leaking.What else could it be.
Jan 21, 2008 at 11:14 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7515d90a87="Cornellious"]Engine problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Automatic 100000 miles
My car is running hot i've replaced the thermostat the water pump is not leaking.What else could it be.[/quote:7515d90a87]
just running hot or its over heating
check the fans if they are working when car hot
check coolant flow
flush system
check head gasket
Jan 21, 2008 at 12:49 PM
