1997 Toyota Corolla NOISE
1997 TOYOTA COROLLA
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
NDUVALNG
Hello Sir, i just bought a toyota corolla ce 1997 model. I have noticed that on driving there is always a strange noise coming from the driver's side tyre area between the pad and wheel area. what is responsible for that could it be a shaft bent or the hub and what should i do. Is it possible to get a used part from car dealers for replacement?
Apr 5, 2008 at 11:59 AM
  • 31,937 POSTS
Have the front brakes check as they may be very low and the wear indicator may be making the noise, check for any play in the wheel bearing, there should be none, check the dust boot on the drive shaft , if it is split and there eis grease leaking, have that attended too. check these things first.
Mark (mhpautos)
Apr 5, 2008 at 6:06 PM
