1997 Toyota Corolla Motor runs rough
1997 TOYOTA COROLLA
GEORGEZXCVBN
Engine Performance problem
1997 Toyota Corolla Two Wheel Drive Automatic
After changing, the two O2 censors, spark plugs, spark plug wires, the coil in the distributor, the gas filter I still have the same problem. The car starts ok. In the morning when I first start the car it runs rough. A few minutes later it settles down and runs ok until I slow down and stop at a light or stop. It then start running rough again almost to the point where it willl stall. I have to change gear to neutral and give it a bit of gas and it settles down. Then I can go. I have had the car in three mechanic shops including a Toyota dealership. Nobody has been able to fix the problem. I am frustrated.... Oh by the way the engine light is on also. Can you please help ?
Aug 2, 2009 at 2:51 AM
MMPRINCE4000
  • 8,548 POSTS
Did anybody scan the PCM for error codes? and if so, what codes did they get?
Aug 3, 2009 at 2:34 AM
