Engine Performance problem
1997 Toyota Corolla Two Wheel Drive Automatic
After changing, the two O2 censors, spark plugs, spark plug wires, the coil in the distributor, the gas filter I still have the same problem. The car starts ok. In the morning when I first start the car it runs rough. A few minutes later it settles down and runs ok until I slow down and stop at a light or stop. It then start running rough again almost to the point where it willl stall. I have to change gear to neutral and give it a bit of gas and it settles down. Then I can go. I have had the car in three mechanic shops including a Toyota dealership. Nobody has been able to fix the problem. I am frustrated.... Oh by the way the engine light is on also. Can you please help ?
Aug 2, 2009 at 2:51 AM
