1997 Toyota Corolla GEAR SHIFT
18,500 MILES • 4 CYL • 4WD • AUTOMATIC
L0RAC
My gear shift is stuck in park and my brake lights are out. The car is still drivable. What can be the problem?
Apr 7, 2009 at 1:41 AM
GRSMNKY
  • 33 POSTS
most likely your car is stuck in park because your brake lights are out. Check fuse for the brake lights, it is probably blown. once the circuit is working the brake light switch will release the shifter once the brake pedal is depressed
Apr 10, 2009 at 3:47 PM
