1997 Toyota Corolla Cranks with ignition switch off
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
RON DENHAM
My starter cranks without firing with the ignition switch off and key removed. Before this happened sometimes the switch (or starter) would just click like a loose battery cable and then it would start ok. Can you help? Thanks
Oct 24, 2010 at 1:27 PM
  • 75,988 POSTS
Its either the starter relay is sticking or the ignition switch is defective
Oct 24, 2010 at 5:44 PM
