1997 Toyota Corolla car alarm
107,444 MILES • 4 CYL • 2WD • AUTOMATIC
TONYSILLER
when i hit the unlock lock button on my keyless entry pad a constant sound emit for about 15 seconds it will not unlock or lock the car i tried to reset keyless entry i thought that that would work but it did not is there any thing i can do to get it working properly?
Sep 24, 2009 at 11:27 AM
MMPRINCE4000
  • 8,548 POSTS
When you use the key to lock/unlock, does it make the same noise?
Sep 24, 2009 at 10:34 PM
TONYSILLER
no the key works fine just when i hit the buttons on the keyless entry pad
Sep 25, 2009 at 7:42 AM
MMPRINCE4000
  • 8,548 POSTS
The signal is either weak (change battery) or the receiver in the car is bad.
Sep 26, 2009 at 12:25 AM
TONYSILLER
i changed the battery in the keyless entry then i tried to reprogram it. I got the noise to stop but is still wont unlock or lock the car. If i hold down the unlock button it will trigger the alarm and then lock the doors but that is all it will do
Sep 26, 2009 at 3:49 AM
MMPRINCE4000
  • 8,548 POSTS
Have you checked the owners manual for reprogramming info?
Sep 27, 2009 at 12:10 AM
