1997 Toyota Corolla belts
RGRANT9
Engine Mechanical problem
1997 Toyota Corolla 4 cyl Two Wheel Drive Automatic
How many belts are there, many or 1 serpintine ? Have lost power steering, water pump (heater runs cool), charging light is on.
Dec 12, 2009 at 11:22 AM
MMPRINCE4000
  • 8,548 POSTS
It has WP/Alt, WP/PS, AC. So replace the WP/Alt, belt. You may have to remove other belts to get to it. Check condition of all belts and replace if necessary.
When replacing belts, always use brake clean on pulleys to make sure they are clean, any contaminants will cause belt slippage.
Jul 27, 2020 at 9:42 AM
