Take it to an alignment shop, this would probably be the best way to diagnose the problem.
It could be an alignment issue (toe, camber), or a mechanical issue (bearings, bushings, ball joints, loose components).
The alignment shop could tell you if it is a simple alignment issue or mechanical.
SPONSORED LINKS
Thursday, March 12th, 2009 AT 6:44 AM
