Raise vehicle, put on stands. Grasp tire and pull/push both vertically and horizontally. If no movement you probably have a tire balance or alignment problem.
If movement, then inspect ball joints, tie rods, bearings, control arm and control arm bushings.
Replace whatever component is worn, get car aligned.
SPONSORED LINKS
Thursday, October 23rd, 2008 AT 6:25 AM
