It is possible you damaged the convertor, they can be damaged by an impact. If damaged they can overheat, clog up and cause many drivability, problems.
Other possibilities are that a connector was damaged (crankshaft sensor for example). You may have also damaged a motor mount.
Best to have it inspected and find the cause.
SPONSORED LINKS
Sunday, December 21st, 2008 AT 9:08 AM
