Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Symptoms
Runs Rough
1996 Toyota Corolla what did i do?
1996 TOYOTA COROLLA
181,000 MILES • 4 CYL • FWD • AUTOMATIC
ATOMIC68
MEMBER
1 POST
i cleaned off the motor now it will hardly run what did i get wet and do i need to replace it
Apr 15, 2008 at 9:47 AM
MMPRINCE4000
Experienced Mechanic
The easiest way would be to scan the PCM and see what sensors are malfunctioning. Then clean them with an electronics cleaner and blow them dry.
Or disconnect electrical connections one at a time and clean with electronics and blow dry. Clean both sides of the connectors.
Apr 15, 2008 at 11:48 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
