HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Runs Rough
1996 Toyota Corolla what did I do?
ATOMIC68
MEMBER
1996 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
181,000 MILES
I cleaned off the motor now it will hardly run what did I get wet and do I need to replace it
Tuesday, April 15th, 2008 AT 4:47 PM
MMPRINCE4000
MECHANIC
The easiest way would be to scan the PCM and see what sensors are malfunctioning. Then clean them with an electronics cleaner and blow them dry.
Or disconnect electrical connections one at a time and clean with electronics and blow dry. Clean both sides of the connectors.
SPONSORED LINKS
Tuesday, April 15th, 2008 AT 6:48 PM
Please
login
or
register
to post a reply.
Related Engine Runs Rough Content
1990 Toyota Corolla Engine Runs Rough, Low Power
Engine Performance Problem 1990 Toyota Corolla 4 Cyl Front Wheel Drive Automatic 255k Miles Engine Idles Rough, Engine Runs Better At...
Asked by
johndc12
1990
TOYOTA COROLLA
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
97 Geo Prizm Runs Rough
I Have A 97 Geo Prizm Which Most People Know Has The Toyota Corolla Motor And Tranny. Anyways, My Transmission Was Going Out, So I Parked...
Asked by
woodenhead72
1 ANSWER
1997
TOYOTA COROLLA
95 Toyota Corolla - Running Rough And Sluggish
I Have A 1995 Toyota Corolla Dx With 128,000 Miles With 1.8 Liter Engine That Was Running Rough, And Would Sometimes Die At Stp Signs/ Red...
Asked by
moses
1 ANSWER
1995
TOYOTA COROLLA
1993 Toyota Corolla Runs Rough When Warm
The Car Runs Fine At An Idle Until It Is Warm, Then It Runs Rough.
Asked by
flyingzebra99
1 ANSWER
1993
TOYOTA COROLLA
2007 Toyota Corolla Idle Runs Rough
Engine Performance Problem 2007 Toyota Corolla 4 Cyl Automatic 19,000 Miles Hi, My Issue Is A Week Or Two Ago I Was Sitting At A...
Asked by
gemini1160
1 ANSWER
2007
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes Benz
How to Read Codes
Online car repair manuals
