1996 Toyota Corolla rough engine idling
MIKE_57
  • 1996 TOYOTA COROLLA
Noises problem
1996 Toyota Corolla 4 cyl Two Wheel Drive Manual
this is an owner type jeep with toyota 4K engine. I can not lower the idling. I used to clean the carburator but still the rough idling exist. I want to know the air passages from the engine to the carburator. I noticed that there are few air hoses are attached to the carburator. Thanks and more power
Thursday, June 4th, 2009 AT 11:13 PM
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
Thursday, June 4th, 2009 AT 11:19 PM
