I replaced the rear turn signal bulb which didnt do anything. I replaced the socket and still nothing would work. All of the other lights in the rear work except the turn signal. The turn signal on the same side up front works... Any ideas?
The rear right turn signal doesnt work. I will be buying one of those things to check if I have power going to it. If there isnt.. Will it be hard to fix?
Feb 20, 2008 at 7:14 AM
