Since it is a manual, the clutch safety switch is a possible cause. This prevents the car from being started without depressing clutch.
Inspect switch and make sure that it is adjusted properly.
It could also be the ign. Switch, or a bad battery connection. But I would start with clutch switch.
SPONSORED LINKS
Monday, June 1st, 2009 AT 7:44 AM
