No power to anything needing key on
120,000 MILES • 1.6L • 4 CYL • AUTOMATIC
DAVIDE123
  • 26 POSTS
90 corolla
new alternator and battery.
Fusible links good.
> Under hood fuses good.
> Inside Lft. panel fuses good.
Key in switch> ding ding> switch on> no power to anything needing key on > turn to start> No click either
Help and thanks
Jan 30, 2016 at 5:41 AM
DAVIDE123
  • 26 POSTS
Additional info the charging (eng/brake light would come on intermittently (when I was still able to drive it)
Jan 30, 2016 at 5:50 AM
  • 31,937 POSTS
drop off the steering coloum trim and test that the ignition switch is actualy switching, do this with a tesst light, the easist way is probe each terminal as you turn to ignition on and it should light up, one will be acc feed and one will be ignition and then you will have the cranking circuit that will light up when you switch to crank.
Jan 30, 2016 at 6:01 AM
DAVIDE123
  • 26 POSTS
I will have to do it later (work) thanks for your reply.
Do you know can engine relay cause this? Thank you for your response.
Jan 30, 2016 at 6:05 AM
  • 31,937 POSTS
Can be a few things but best to start at the switch and work down the circuit as that way nothing can be over looked,
Jan 30, 2016 at 6:08 AM
DAVIDE123
  • 26 POSTS
Thanks again. I was able to drop. The trim (15 min left 4me). I see some plug connections, I am not sure where to test> I have a digital VM to use to test.
Jan 30, 2016 at 6:24 AM
DAVIDE123
  • 26 POSTS
Not sure where the terminals are yet...
Jan 30, 2016 at 6:25 AM
  • 31,937 POSTS
it will be the round switch attached to the back of the ignition barre land key assembly.
Jan 30, 2016 at 6:28 AM
DAVIDE123
  • 26 POSTS
Ok I will test tommorrow I hope. My wife has a lot of things planned, but thanks again. and Bye for now...
Jan 30, 2016 at 6:32 AM
  • 31,937 POSTS
Ok, re post with what you find, just so you know, i am in Australia so the time difference is an issue, it is Sunday morning here and tomorrow i will not be on till the evening my time, so if you post and hear nothing, hang in there and i will respond asap.
Jan 30, 2016 at 6:36 AM
DAVIDE123
  • 26 POSTS
Hi again mate trying to post testing...
Jan 31, 2016 at 5:37 AM
DAVIDE123
  • 26 POSTS
Here is what I see:
Round Cyl > Round Plastic on the end > Group of taped wires out of it > Into an 8 pin plug.
AND 2 wires coming out > into a 2 pin plug.
Will post colors on next post...
Jan 31, 2016 at 5:41 AM
DAVIDE123
  • 26 POSTS
I can test back of plug but not sure which is which.
Back of 8 Pin:
BLK/RED [ ] [ ] BRN
BLK/BLU [ ] [ ] BRN/WHT
BLK/YEL [ ] [ ] (OPEN)
BLK/WHT [ ] [ ]BRN/RED
2 Pin (lighter gauged wires) Plug:
Grn/Wht[ ] [ ] Grn/Wht
Jan 31, 2016 at 5:46 AM
DAVIDE123
  • 26 POSTS
Back of 8 Pin:
BLK/RED [ ] [ ] BRN
Jan 31, 2016 at 5:47 AM
  • 31,937 POSTS
this thread will be closed use the new link.
Feb 3, 2016 at 3:14 PM
