here's my problem i had to fix the positive battery clamp so i cut the one originally off totally because it was corroded and i could take it off with a wrench i even cut this brass piece that runs with the positive wire to the terimnal that is my problem what is it and what does it do i need to get that brass connection or if there is somthing out there that i can replace the positive wire and that brass connecter
Mar 18, 2009 at 7:13 AM
