1996 Toyota Corolla not sure if heater core is going or def
1996 TOYOTA COROLLA
CUPCAKES19440
Heater problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
I own a 1996 toyota crolla and the side windows are fogging inside on both sides. need help.5.
Dec 21, 2008 at 3:12 AM
MMPRINCE4000
  • 8,548 POSTS
Check air flow through side defroster vents, if OK, the use an anti-fog treatment on windows.
If air flow is restricted, then blend door, hose hookup to vent has come loose.
Dec 22, 2008 at 1:18 AM
