1996 Toyota Corolla need diagram/ location of the 3 belts i
1996 TOYOTA COROLLA
SC1313
Engine Mechanical problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
how to access/ loosen the belts to remove them so that they may be replaced
Mar 29, 2009 at 5:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Loosen pivot bolt (some models use a tension adjustment bolt) then push the component inwards to loosen that specific belt..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_383.jpg
Thanks for using 2CarPros.com!
Mar 29, 2009 at 4:55 PM
MMPRINCE4000
  • 8,548 POSTS
To add to what Blue said:
The AC belt also has a tensioner, and PS usually runs off rear or WP drive. Start with belt farthest out and work inward.
Mar 30, 2009 at 1:32 AM
