1996 Toyota Corolla Loud noise when making a sharp U-turn
1996 TOYOTA COROLLA
90,500 MILES • 4 CYL • FWD • AUTOMATIC
AAHAMED
I am hearing a noise from the rear passenger side (it appears so but could be from the front also, I guess) only while making sharp u-turns or full length turns. I doubt if it has to do with the ball bearings getting worn out on the suspension.
I would very much appreciate your valuable feedback as to what is causing this problem.
Thanks & Regards,
Ashraf
Aug 28, 2008 at 10:57 AM
  • 31,937 POSTS
HI there,
If it is a knocking noise, you will have faulty C.V joints in the drive shaft, get these inspected.
Mark (mhpautos)
Aug 28, 2008 at 11:01 AM
