[quote:772d6abffb="Honolulu"]My vote is still a loose power steering belt. Suggest applying some belt dressing to the contact surfaces of the belt. Be careful, it can be difficult to safely shoot some of this stuff on; it's commonly available in a small spray can.
The old timer's remedy is to test by puttting a dribble of water on the suspect belt while squealing. if the noise stops, it's the belt slipping against the pulley. Old timer's remedy is to rub some plain old candle wax on the contact surface of the belt. Tighten the belt and make sure the reservoir is correctly topped up with the recommended fluid.[/quote:772d6abffb]
I think I agree with you, it must be the belt. It has been hard to do any tests while it is squealing, since it only happens briefly, only the first time I start the car in the morning, and only when I am moving -- so I cannot get out and look at it and can't drive it for the mechanic to hear it.
The tricks of putting water or wax on the belts are a good idea. I suspect I am going to ultimately need a new belt, though. Thanks.
Feb 27, 2010 at 1:27 AM
