1996 Toyota Corolla hi
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
KYKY
hi , my heat at rear mirror doesn't work .it's hard when raining. can you tell me why ? how can I fix it . thank you
Nov 6, 2009 at 7:50 AM
STEVEW84
  • 673 POSTS
There will be a connector on each end of the back window. When you turn the rear defrost switch on then one should have power and other should be ground. If you have it then you need a new back window. If you don't then need to do some troubleshooting.
Nov 6, 2009 at 8:13 AM
