1996 Toyota Corolla engine weight
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOAT
buying a engine stand and a hoist to rebuild the engine but i need to know if i need the 1000lb or the 2000lb one... please help, cant find the info anywhere.
Apr 27, 2009 at 7:33 AM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:45cb414c16="JOAT"]Engine Mechanical problem
1996 Toyota Corolla 4 cyl Two Wheel Drive Automatic 160000 miles
buying a engine stand and a hoist to rebuild the engine but i need to know if i need the 1000lb or the 2000lb one... please help, cant find the info anywhere.[/quote:45cb414c16]
If you plan on using it for any other engines I would recommend the 2000lbs stand. I prefer the heavier duty stuff. It will take more abuse and last longer.
Apr 27, 2009 at 7:44 AM
