1996 Toyota Corolla Engine noise goes "Wahhhhh"
JOEMCJOE
  • 1996 TOYOTA COROLLA
Noises problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
Hey, I have a 96 corolla about 154,000 miles on it. 4 cyl engine. Recently started makeing a sound from the engine that sounds like a small dirt bike or a lawnmower. Likw a "whaaaaahh" sound. It gets pretty loud on freeway and is constant. The noise slowly goes away when decelerating. Can It be a cracked exhuast manifold or gasket?
Tuesday, November 10th, 2009 AT 7:37 PM
MMPRINCE4000
  • 8,548 POSTS
Check the intake system, including air filter and make sure all connections are correct and air filter cover is not loose.
Exhaust manifolds usually make a popping sound, but check it anyway, look for any black soot around manifold.
Wednesday, November 11th, 2009 AT 5:56 AM
