1996 Toyota Corolla coolant leak
162,000 MILES • 4 CYL • FWD • AUTOMATIC
BARNARD1177
thank you for your time.i have a 96 corolla dx 1.8 i just replaced the radiator,hoses,and cap.Now i noticed there is coolant leaking from the transmission gasket not the pan.any ideas as to why ?
Jan 7, 2008 at 3:14 AM
  • 31,937 POSTS
Hi there,
Have the cooling system pressure tested and check for leaks that will be running down onto the transmission, as there is no cooling system components in or on the transmission.
Mark (mhpautos)
Jan 12, 2008 at 3:40 PM
