1996 Toyota Corolla cable assy
LYNNBEN
Heater problem
1996 Toyota Corolla 4 cyl Two Wheel Drive Automatic
I need to replace only the cable assy that switches the heat to floor, defrost, vent. All other cables work fine. How can I obtain a part number for this and is this cable assy available without having to buy the whole assy.
Apr 20, 2009 at 4:37 AM
MMPRINCE4000
  • 8,548 POSTS
If cable is broke in center or an accessable area, you can buy cable repair kits at most autoparts stores.
Otherwise you will most likely have to get cable from Toyota parts.
Apr 20, 2009 at 11:31 PM
