1996 Toyota Corolla BOILING
219,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUEBELL1953
  • 5 POSTS
WHY DOES MY CAR SOUND LIKE IT IS BOILING OVER WHEN I TURN THE MOTOR OFF. IT DOESN'T SHOW IT IS RUNNING HOT. IT IS NIRMAL
Sep 8, 2009 at 5:01 AM
  • 75,988 POSTS
Check and test the coolant temperature sensor or the engine temperature gauge switch could be out of calibration-Boiling over you're overheating-start by replacing the thermostat if it continues get it block and pressure teted.
Sep 8, 2009 at 7:42 AM
SUEBELL1953
  • 5 POSTS
THANK YOU VERY MUCH.
Sep 8, 2009 at 8:48 AM
