WHY DOES MY CAR SOUND LIKE IT IS BOILING OVER WHEN I TURN THE MOTOR OFF. IT DOESN'T SHOW IT IS RUNNING HOT. IT IS NIRMAL
Sep 8, 2009 at 5:01 AM
✓Experienced Mechanic
Check and test the coolant temperature sensor or the engine temperature gauge switch could be out of calibration-Boiling over you're overheating-start by replacing the thermostat if it continues get it block and pressure teted.
