1996 Toyota Corolla axles repalce
1996 TOYOTA COROLLA
176,000 MILES • 4 CYL • 2WD • AUTOMATIC
VINNY NGUYEN
hi
i got 1996 toyoto corolla 176000 miles ,if i want to replace a drive shaft would you help me how to remove and putting a new one in please. there is certern way to put in?
thank you so much
Feb 11, 2010 at 4:59 AM
MMPRINCE4000
  • 8,548 POSTS
Old axles "pop" out, use a prybar.
You must remove the axle at the steering knuckle, so you remove the outer tie rod end, lower ball joint, axle nut, unbolt caliper and hang it out of way.
Replace seal at transmission.
New axle pops in, you can use a long heavy screwdriver on tripod notch to help axle pop in.
Feb 11, 2010 at 11:23 PM
