1996 Toyota Corolla Adding freon
116,784 MILES • 4 CYL • FWD • AUTOMATIC
JOEY573
I want to add freon to my car but don't know how to. I have the freon and the hose I need to do it. Any info I get will be appreciated. Thank you
May 16, 2009 at 12:41 AM
MMPRINCE4000
  • 8,548 POSTS
You add to low side, the connector should only fit the low side and the high (pressure) side should be clearly marked.
My suggestion is to take to an AC shop. The fact that it needs freon means there is a leak in the system and the leak must be fixed.
May 16, 2009 at 2:21 AM
