1995 Toyota Corolla Strange ticking sound in the engine and
1995 TOYOTA COROLLA
SONGBIRDLA
Engine Mechanical problem
1995 Toyota Corolla Automatic
My corolla is making a weird ticking noise when it's off. We haven't driven it for several days, but for some reason it started making this noise today. It's coming from the box to the right of the battery that holds the fuses to the horn and fan and a few others I believe. I'm not sure if starting the car will help or hurt it, so any advice would be appreciated.
Dec 17, 2009 at 6:52 AM
MMPRINCE4000
  • 8,548 POSTS
It is a relay. Remove cover to fuse box, put on some gloves (it will be hot) and isolate bad relay. Disconnect - battery cable to change relay.
Dec 18, 2009 at 1:55 AM
