1995 Toyota Corolla Speedometer/odometer not working
1995 TOYOTA COROLLA
298,000 MILES • 4 CYL • FWD • MANUAL
FAICON9493
I recently had the car in to replace the starter and wiring harness. After I picked the car up, I found that the speedometer and odometer were not working. They worked prior to the repair. What could have happened and how easy & costly is the fix?
Nov 24, 2008 at 5:39 AM
  • 31,937 POSTS
Hi there,
Take it back and ask them to check the speedo cable conection for you, it may have failed or is not connected correctly, this will take a few Minuit's.
mark
Nov 24, 2008 at 7:59 AM
