1995 Toyota Corolla Oil pan
HAYDER1
Shakes or Wobbles problem
1995 Toyota Corolla 4 cyl Two Wheel Drive Automatic
How do I uninstall the oil pan.
Nov 11, 2008 at 6:05 AM
  • 31,937 POSTS
HI there , With the car jacked up on stands, drain sup, remove exhaust engine pipe, undo front & rear engine mounts and unbolt cross member, the engine is still supported with side mounts so it is quite safe, unbolt sump and remove, remember that these sumps use a chemical sealant and not a gasket. all old sealant must be removed completely.
mark (mhpautos)
Nov 11, 2008 at 7:47 AM
