no injector pulse
250,000 MILES • 4 CYL • FWD • AUTOMATIC
TWINTRAIN
the car has not been driven in over 2 year. Replaced the fuel pump, good pressure. It has power to the injectors but no pulsation. Engine will start with starting fluid but will not stay running. Is it the computer?
Jan 3, 2010 at 11:15 PM
MMPRINCE4000
  • 8,548 POSTS
Either ECM or the injectors (sitting so long nay have built up a significant amount of varnish).
Use a noid light to see if ECM is commanding injector pulse. If so, then injectors, if not then ECM or injector fuses.
Jan 4, 2010 at 12:27 AM
