1995 Toyota Corolla Low RPM when I turn on the AC.
187,000 MILES • 4 CYL • 2WD • MANUAL
JOSEMBERROA
I have a new alternator, brand new spark plug cables. new ignition, new header, 2'1/2' exhaust , new blower, new air sensor, new belts, new neutral pulley where the compressor belt goes.
and my car no feel like turning off when I start the ac. I i leave it on without the compressor runs fine, but as soon I turn it on the car vibrate a lot. and when im in a red light I have to pump gas so that way the car continue running on a red light.
I don't want to kill my car with this... [img:7323998693]http://www.2carpros.com/forum/automotive_pictures/460748_IMG00456_1.jpg[/img:7323998693]
Jan 8, 2010 at 2:14 PM
  • 75,988 POSTS
Check and test the idle up solenoid -when the computer sees a signal from the compressor engagement it will tell the IACV and TPS to raise the RPM to compensate for the additonal load
Jan 8, 2010 at 2:25 PM
