1995 Toyota Corolla Loss of 12VDC ignition power to car ste
199,000 MILES • 4 CYL • FWD • MANUAL
BAZOOKA JOE
I recently installed a stereo and it would not power up. There is no 12VDC at the dash end of the wiring harness on the ignition 12VDC line with the car turned on. The digital clock does has only 12VDC battery power at its wiring harness and does not come on with car turned on.
All fuses check sat. Battery 12VDC check sat at stereo harness. All other dashboard electrical functions operating normally.
Is there another inline fuse, or fusable link on this line??? Please help.
Jun 9, 2008 at 1:16 AM
KHLOW2008
  • 41,812 POSTS
Hi Bazooka joe,
There should be a 12 VDC power supply at the radio harness if the switch is turned to ACC or on. If none then check for a blown radio fuse at underdash fuse box.
Jun 9, 2008 at 5:18 AM
