1995 Toyota Corolla ignition
1,995 MILES • 4 CYL • FWD • MANUAL
DPAL4909
When I start the vehicle there is a sucking sound that lasts for about two-three seconds. I have had the car for 11 years and it has never made this sound. It doesn't matter whether the engine is hot or cold. I am trying to troubleshoot the problem, and am unsure if I should have the starter checked, or should look to an intake valve, or something else. Any suggestions?
Feb 10, 2009 at 8:51 AM
MMPRINCE4000
  • 8,548 POSTS
Check oil filler cap, PCV valve and all vacuum lines, including the brake booster line.
Also inspect the intake hose to TB and air filter.
A valve/shim problem would not normally go away.
Check intake manifold bolts also, make sure they are torqued properly and not loose.
Feb 10, 2009 at 9:32 PM
