Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Idle Air Control
Replace/Remove
1995 Toyota Corolla idleing
1995 TOYOTA COROLLA
221,000 MILES • 4 CYL • FWD • AUTOMATIC
BUDDA40
MEMBER
1 POST
my car makes looping noise when car is in idle. i change the wires ,cap ,rotor,spark plugs,idle air control valve.can u please help me?
Dec 12, 2008 at 1:26 AM
MMPRINCE4000
Experienced Mechanic
Check mechanical timing on distributor with timing light.
Inspect timing belt for broken cogs/looseness.
Also check fuel pressure with a mechanical gauge.
If equipped with EGR, remove and clean the EGR valve pintle and passage in intake manifold.
Dec 13, 2008 at 2:00 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
