1995 Toyota Corolla Humming and Vibration
163,000 MILES • 4 CYL • FWD • AUTOMATIC
CMINIUM
I have a 95 Toyota Corolla that has 163,000 miles on it. I had the tires replaced recently and then when I was going to rotate the tires I noticed that the front passenger side tire was on backwards and that they striped some of the wheel bolts. I took it back to firestone and they were more then happy to fix what they had screwed up. The problem now is that the front driver side tire makes a humming noise. I can feel it in the steering wheel and the pedals when I drive and noticed that it has no correlation with how fast the engine is going just how fast the tire is spinning. The humming changes pitches when I brake and stops completely when I turn to the right. I tried taking the tire and wheel off to see if there was anything obvious but after checking the ball joints, tie-rod end, and brake caliber I can find nothing loose or that doesn't seem to be working correctly. Any ideas?
Aug 11, 2009 at 3:16 PM
  • 110,248 POSTS
When you say they put the tire on backwards, is this a directional tire? Also, is the tread cupped or worn in a strange way?
Aug 11, 2009 at 3:57 PM
CMINIUM
The tires are worn a bit on the inside. When the noise started I thought rotating the tires would help but it still makes the same sound. Yes it was a directional tire. The manager at firestone seemed very upset that is was not on right. I did a back to front rotation on the tires, should I switch sides too?
Aug 12, 2009 at 5:09 AM
  • 110,248 POSTS
When you rotated the tires, did the noise chance places? Also, does the sound change when you make turns?
Finally, I would demand that Firestone replace the tire with a new one. If it's a directional tire and they put it on backwards, god knows what could happen to the tire.
Aug 12, 2009 at 8:51 AM
CMINIUM
The sound did not change places when I rotated the tires, and it stops (the sound and the vibrations,) when I turn to the right.
Aug 12, 2009 at 11:18 AM
