1995 Toyota Corolla Hitching while going through town
232,000 MILES • 4 CYL • 2WD • MANUAL
CAPPY144
My corolla starts fine and ,at first, runs fine. After about 10-15 minutes, it starts hitchin, as if one of the injectors wasn't firing. Very low power. If I shift down, it acts better and appears to be normal. I stop, and the car idles fine. Sometimes, I will smell ozone and occasionaly see a bit of smoke. If I go on the turnpike, it will take forever to get up to speed. Once up to highway speed, it will go fine. When I slow back down to intown speed, and stop and go travel, it will start acting up again.
Has anyone had this problem? thank you for any help.
May 24, 2010 at 1:30 AM
MMPRINCE4000
  • 8,548 POSTS
It sounds like a clogged convertor, have it tested at a trusted garage, they will perform a backpressure test.
May 25, 2010 at 1:30 AM
