1995 Toyota Corolla gears
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAM76543
Just changed oil Kept Engine running. Gear stuck in park position Clicking sound after I press break fully but it never moves out of park position
Apr 22, 2008 at 1:46 PM
RAM76543
The override button is under a small plastic cocer of 1 cm size at bottom of the gear stick. Just took off this button, inserted a screw driver pressed it and the geaars shift lock is releasd!!
Then checked all fuses and ONE fuse controlling brake lights was bust. Replaced this and the SHIFT lock system started working very well!!
RVedu
Apr 22, 2008 at 3:32 PM
